waiting for manual help please
- koloj
24 Jun 2014 10:56
Adjusting valves 1980 kz 750 4 need order in which to torque cam holder Boltz and lb waiting for manual but if u can spare 5 min thanks
Re: waiting for manual help please
24 Jun 2014 11:30
Here's a site w a manual & wiring diagrams.
mbsween.bike-night KZ750L3 page
Scroll down & click "The Bible" link.
Note: some of the wiring diagrams are mislabeled in the links. The 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4. search tags mbsween KZ750L3
- dom2570
24 Jun 2014 17:35
I just did a valve job on my 82 KZ70 4. My Clymer manual wasn't much help when it came to the cams. It said to lighty tighten down the left side cams holders to set the cams, Then gradually tighten all of the cam holders to 8.5ft-lbs.
It was my fist valve check and made it out alive, good luck.
Whip it like a mule!
- koloj
24 Jun 2014 21:38
Well thanks for your help guys....I did the valve check and know the shims I have to get now but also in the midst found with cams off and commpression test some valve are leaking so remove the head and now gonna have to reset the valves...but up side of it pistons look nice and snug and head gasket sound and saveable.....also I'll get clean the head make it look clean....so hope in she gonna purr real nice when I'm done
