550 trans in a 1000
- jonarmstrong
550 trans in a 1000
24 Jun 2014 10:51
I had an older motorcycle mechanic tell me a kz550 trans will go in a kz1000. Any truth to this? If so, any cons to this swap?
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
Re: 550 trans in a 1000
24 Jun 2014 12:20
kawasaki.com may be of help toward determining which transmission parts may be interchangeable, if any.
- steell
29 Jun 2014 23:11jonarmstrong wrote: I had an older motorcycle mechanic tell me a kz550 trans will go in a kz1000. Any truth to this? If so, any cons to this swap?
Compare the width of the gears in the two transmissions, then tell me if you think there are any cons to this swap. I don't believe it's possible anyway, the fellow telling you that was probably talking about the 550 trans fitting in the 650/750 four motors.
The following user(s) said Thank You: jonarmstrong
- pete greek1
30 Jun 2014 06:12
Maybe his way of thinking is, if you use a 550 trans. he'll have room for 2 more gears, & you can have a 7 speed :laugh: :laugh: :laugh:
- gengomerpyle
30 Jun 2014 13:17
i heard the same thing that it would fix in a 750R1
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
