Spark Plug Choice KZ1000
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
23 Jun 2014 12:29
#637707
I am buying new spark plugs for my Kz1000 and found that there are three choices (All NGK) B8ES, B9ES, and B7ES. Which should I buy? I saw another thread on this but I didnt really explain the differences.
I have a '80 LTD 1075cc 4:1 Kerker Stock Pumpers with KN.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
Re: Spark Plug Choice KZ1000
23 Jun 2014 13:29
#637719
Your bike is a larger than stock bore so that may make a difference, but the 1981 Kawasaki Service Manual calls for the B8ES plugs. The B9ES plug is one heat range colder; the B7ES is one heat range hotter. Colder plugs are normally used when the bike is ridden very hard. Hotter plugs normally are used if the bike is used very gently. Ed
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
23 Jun 2014 13:30
#637722
the manual says B8ES
the different number stands for the heat range of the plug.
  • pete greek1
  • pete greek1's Avatar
23 Jun 2014 13:37
#637723
I use B8ES in my 80 LTD 1000 with 1075 kit & RS 34s & it runs Great
Pete
  • zed1015
  • zed1015's Avatar
23 Jun 2014 13:39
#637724
Stick 9's in it.
  • MFolks
  • MFolks's Avatar
23 Jun 2014 14:35
#637734
Another choice(if you can find them) is the Denso W24ESU's, same spark gap.
  • LarryC
  • LarryC's Avatar
23 Jun 2014 16:54 - 23 Jun 2014 16:56
#637749
I always run B8ES or B8EV in street motors, even if they're pumped up. Never any problems. V's cost more but IMO they're worth it.
You can even run Champions if you like but do not use anything but the direct cross over plug because Champion heat ranges and NGK are very different. One range in a Champ is equal to about 3 in NGK.
Larry C.
Last edit: 23 Jun 2014 16:56 by LarryC.
  • Motor Head
  • Motor Head's Avatar
23 Jun 2014 18:16
#637757
+1 on the Denso Plugs. I use their racing plug, W24ES-ZU.
I've always like the Denso and NGK plugs.
There are a lot of different electrode types out there. That is one of the big differences in plugs. Then of course there are resistor plugs, which you Do Not Want. So if someone tries to sell you a set with an "R" in the part #, say BR8ES, pass and get the non resistor B8ES.
