Crack in the smog head
  • 771000LTD
  • 771000LTD's Avatar Topic Author
20 Jun 2014 15:30 - 21 Jun 2014 16:22
#637318
when I was removing the smog hardware and cleaning out the soot I discovered this crack. I am guessing that this was done because the cam cover bolts on #2 were not tightened enough causing this damage .Question is will this headcover be useable.?
Well i have tried everything to load pics and keep getting the big blue wall SERVER ERROR.
I have re-sized,and also tried to load pics i have sent before and same result,Im sure its operator error so Im bailing on trying anymore,I will use the cover and hope for the best.
Thanks to those who tried to help.
Last edit: 21 Jun 2014 16:22 by 771000LTD.
  • pete greek1
  • pete greek1's Avatar
Re: Crack in the smog head
20 Jun 2014 18:05
#637331
Pics. would help !!
The following user(s) said Thank You: PLUMMEN
  • 771000LTD
20 Jun 2014 18:18 - 20 Jun 2014 19:16
#637334
I have been trying for 2hrs.
Will welcome any advice
Last edit: 20 Jun 2014 19:16 by 771000LTD.
  • Nessism
  • Nessism's Avatar
20 Jun 2014 20:19
#637348
771000LTD wrote: I have been trying for 2hrs.
Photobucket. Then link the img code in the body of your post.
