Crank is bent...
  • CaptainDeVoe
  • CaptainDeVoe's Avatar Topic Author
Crank is bent...
19 Jun 2014 20:20 - 19 Jun 2014 20:23
#637239
i recently was given a 1981 kz650, it was dropped on its left side broke the stator cover and stator and after i removed the old rotor i unfortunately found it bent the end of the crank that is tapered to seat the rotor. Do i have an options other than replacing the crank. i wasnt really wanting to do a engine tear down...
Last edit: 19 Jun 2014 20:23 by CaptainDeVoe.
Re: Crank is bent...
19 Jun 2014 20:34 - 19 Jun 2014 20:37
#637242
CaptainDeVoe wrote: i recently was given a 1981 kz650, it was dropped on its left side broke the stator cover and stator and after i removed the old rotor i unfortunately found it bent the end of the crank that is tapered to seat the rotor. Do i have an options other than replacing the crank. i wasnt really wanting to do a engine tear down...
Hello, CaptainDeVoe, and WELCOME to KZr!
Another option would be to replace the engine with a good used example.
Perhaps from ebay. There are several listings.
Do an ebay search for kz650 engine.
Could also consider starting another topic in KZr Classified Wanted forum.
Good Fortune! :)
Last edit: 19 Jun 2014 20:37 by Patton.
