KZ400 piston , 13001-1001 / 13001-1001E
  • nizzalotti
  • nizzalotti's Avatar Topic Author
19 Jun 2014 16:35
#637216
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHey guys
Last summer I burnt a hole in one of the pistons on my 79' KZ400 B2 ... was ringing it a little hard .
Holes in my carb diaphragm , intake rubbers and pod filters with no jet change .
The dilemma I have is that I have sourced 1 standard piston for it (#13001-1001)
... and want a second fresh one also ... this one has popped up on ebay and I'm not sure if it is the exact same part as the one I have .. it is listed as a #13001-1001E ... it seems the E is hand written on the box in the photo.
Can any one tell me if this is the same as the first piston? A standard KZ400 B2 piston?
Also looking at a set of after market piston rings ... any advice on them? .. best to go genuine?
  • Nessism
  • Nessism's Avatar
Re: KZ400 piston , 13001-1001 / 13001-1001E
20 Jun 2014 09:06
#637269
I see no reference to the "E" part number in the fishe.
As for the rings, those aftermarket rings would most likely be fine, but I'd figure out cost before deciding.
  • nizzalotti
21 Jun 2014 14:12
#637413
awesome thanks ... i will grab it
  • bountyhunter
  • bountyhunter's Avatar
21 Jun 2014 17:06
#637438
I would mic the cylinder walls to find out if they are scored or worn and would need the next oversize piston.
  • nizzalotti
26 Jun 2014 20:15
#638096
yep just had this done while i had valves and seats cut ... turns out i rushed a bit buying the standard pistons and rings .... engine shop informed me I need at least 20 thou over pistons and a bore.
will put a post up re: wanted over size kz400 b2 pistons
doh!!!
