cam timing again.
- crackfox
cam timing again.
19 Jun 2014 09:48
Hello all, busy rebuilding my top end and have a question about which timing Mark to use. My manual shows the 1/4 tdc in the diagram but says to use the tdc Mark in the following paragraph. I may however have already bent some valves as I stupidly set my exhaust cam 180 degrees out. I turned it over by hand and initially thought I had great compression (having just had a rebore) until no.4 inlet valve snapped back into position. I then realized it must have been in contact with no.4 exhaust valve. My phoned my local bike shop and they doubted any damage would have been done with the valves being 8mm. Having just read similar problems on site I'm now more worried about the expense I've caused.
- peter1958
- Banned
Re: cam timing again.
19 Jun 2014 10:38
What kind of bike might help
www.kzzone.com/
- crackfox
19 Jun 2014 11:47
Sorry forgot to say, mk2 z1000 from 1979. I know I may have damaged valves, I just hope my new wisecos are ok. Simon.
- 4TheKZ1000
19 Jun 2014 12:02 - 19 Jun 2014 12:04
1 or 4 at top dead center
that's T on advancer
Last edit: 19 Jun 2014 12:04 by 4TheKZ1000.
- crackfox
19 Jun 2014 14:05
1 or 4 ? I presumed it meant a quarter before tdc. Should I be setting it at T then ? Thank you.
- slayer61
- KZR FLAG RELAY CARRIER #62
19 Jun 2014 14:14Yes. the T for 1 and 4... it's the same thing and completely different from the T for 2 and 3crackfox wrote: 1 or 4 ? I presumed it meant a quarter before tdc. Should I be setting it at T then ? Thank you.
The following user(s) said Thank You: crackfox
- 4TheKZ1000
19 Jun 2014 14:18
both pistons in cylinder 1 and 4 are at the top of there stroke at the same time ........ 2 and 3 pistons are at the bottom of stroke at same time
not a 1/4 before anything.
when I time my cams, I set cylinder 4 at top dead center on cylinder 4 by viewing the advancer as I turn advancer bolt.
since everything I have to do is all on left side I don't have to move from side to side.
- crackfox
22 Jun 2014 04:52
Thanks for the help. I think I've found the real problem. Wrong cams. I used my mk2 cams on an earlier head. Apparently the cam sprockets have different amounts of teeth. Simon.
