Choke needed to start
- TheForumTroll
17 Jun 2014 08:16 - 17 Jun 2014 08:17
My bike won't start without choke full on unless it have just been started and run. This isn't normal is it? It's 15-25c outside so it's not exactly cold. I'm new to KZ's but my other bikes didn't need choke so I was wondering if something need adjusting.
If it isn't normal, what do I check? Battery is good but I haven't checked anything else electrical except looking at it (looks almost new). It runs fine when hot.
-[ KZ700-A1 '84 ]-
Last edit: 17 Jun 2014 08:17 by TheForumTroll.
- Grumpy Ole Artist
- Eschew Obfuscation!
Re: Choke needed to start
17 Jun 2014 08:49
On mine, if it is the first start of the day, I always put on full choke, no throttle, first kick, vroom! Usually back choke off slightly after bike is started...If the bike is running fine otherwise, I would not sweat it
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- TheForumTroll
17 Jun 2014 08:56 - 17 Jun 2014 08:59
It doesn't start that easy. Mine doesn't have a kickstarter though, so might not be kicking as hard.
I'm not sure it will start when it gets cooler but who knows.
Edit:
I think I have already asked about the electrical part now I think about it. Sorry about that, my memory isn't that good.
Edit:
-[ KZ700-A1 '84 ]-
Last edit: 17 Jun 2014 08:59 by TheForumTroll.
- Topper
17 Jun 2014 13:04
15C is 59F. I'll second what the Grump said and say don't sweat it. That choke's there for a reason, to help start the bike when the engine is cold.
If it's not starting easily you may have other issues going on. I'd suggest you start a new thread describing the starting issues.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
The following user(s) said Thank You: TheForumTroll
