- Thank you received: 1
Exhaust
- hotdogg
- 1982 kz750 spectre
1982 kz750 spectre
- Thank you received: 1656
Since the Spectre has the same exhaust holder studs, I would have thought it could use the stuff from any 750-4, but I really don't know. The collars are listed as Active limited quantity at Kawasaki.com.
- hotdogg
exhaust holders -->> collars -->> headers -->> new gaskets -->> engine.
- slayer61
- KZR FLAG RELAY CARRIER #62
Typo Martin?martin_csr wrote: Yes. The collars are fitted between the carb holders & exhaust header flanges.
carb holders :blink: -->> collars -->> headers -->> new gaskets -->> engine.
- Thank you received: 2098
- wireman
- Thank you received: 299
- hotdogg
1982 kz750 spectre
92027-1456 collar
Can Google 18069-1021,
and also Google 92027-1456,
for links to aftermarket and ebay listings.
Would also consider starting a topic in KZr Classified forum -- "Wanted."
Would also do an ebay search for KZ750 exhaust clamps.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Models with black color exhaust systems will probably have different part numbers assigned to the clamps and/or collars than assigned to models with metal color (standard chrome) exhaust systems.
Am thinking (but not positive) that the exhaust clamps and split collars on the KZ750 4 cylinder models are the same except for the color. But this may be confirmed on the kawasaki.com site.
