Knocking engine - need your advise
- jcote75
09 Jun 2014 20:10
HI everyone,
I went to look for a new bike today. Its'a 1981 KZ1000J.
The bike has around 50,000miles and never been rebuilt.
The bike seem to have been sitting for a few years without running. The new owner told me that the previous owner had put some oil in the gas tank to store it.
Now that the mix of oil and gas had pass, the bike start pretty well but revs around 3,000 to 4,000 rpm without any choke and after 1 minute or 2, it come back to normal speed.
My concern is on respect some bad knocking that can be hear at idle. It's not continuous but quite frequent. It' doest knock when riding but I doubt it.
The new owner tell me it might be the cam chain that need ajustment.
The carbs seem to need a good clean up. Would it be the cause for the high rpm and the knock in the engine (from too much fue in a cylinder?)
Thanks in advance for your help
Joce
Joce
- wireman
Re: Knocking engine - need your advise
09 Jun 2014 20:19
If carbs are out of synch you can get a little cam chain slop at lower rpms,with that many miles it could also have a lose timing chain.
- jcote75
09 Jun 2014 20:22
Ok. it aint no rattle. Really sound like a glunk glunk.... :ohmy:
- ZERO
10 Jun 2014 02:53 - 10 Jun 2014 02:55
Clean the carbs. When the carbs are dirty and a cylinder cuts out it often sounds like a knock. The revving also sounds like an air leak in the intakes somewhere.. While the carburetors are off, fully inspect your intake boots and any vacuum plugs for dry/cracked areas and replace them if in question. Unless you can do the work yourself, it might not be a good investment unless the bike is like under $600. Intakes and carb cleaning will easily set you back $400. And you might still have engine issues.....
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
Last edit: 10 Jun 2014 02:55 by ZERO.
- LarryC
10 Jun 2014 04:09
A loose cam chain in those engines will make a knocking sound. It's the same in all Kaw motors with hyvo cam chains. Carburetors out of synch will enhance that noise significantly and can also make it knock at low RPM even if the cam chain is adjusted properly. You may have one or both problems. Both are easily corrected without braking the bank if you have mechanical skills.
Download the service manual.
Based on your symptoms the carbs need to come off for cleaning anyway. While they're off it's your perfect opportunity to address the cam chain tensioner. Follow the procedure in the service manual for tensioner installation.
Larry C.
- jcote75
10 Jun 2014 04:34
Thanks
I can do all of that work. I just did'nt want to have to deal with major problem such has crankshaft or main main bearing problem.
The bike is clean and complete, so fir the right price, it might be a good bike
- Z1Driver
- love the smell of triple smoke
10 Jun 2014 10:10 - 10 Jun 2014 10:14
My guess is you might be hearing the clutch making noise because the carbs are not balanced. A rod bearing is going to sound deep. Keep in mind this engines are built to last. I have seen several Concours 1000's with 100,000 miles plus. There are a couple running around with 300,000 miles. Stand next to one of these bikes at idle and you'll swear the cams are coming through the valve cover at any second.
Like others have said, if the carbs are out of synch, these Z1/KZ motors will make some racket. In fact I thought the same was going on my 900. A friend of mine said with the amount of miles I had put on the bike it would have blown up if the noise was rod knock. A carb synch cleared a bunch of noise and it didn't sound like it was coming apart any more.
Might also check to see if the carb boots are old and cracked while you have the carbs off.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 10 Jun 2014 10:14 by Z1Driver.
- KZJOE900
- Administrator
Super Users
10 Jun 2014 11:41
I wouldn't run the bike until you get the cam chain adjusted. I'm convinced a lose chain is what shredded my front cam guide. And that's a major a pain to replace.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- jcote75
11 Jun 2014 21:25
Got the bike tonight.
#1 wasn't firing so this was causing the knocking.
Open up the carbs and they had a lot of dirt in it so cleaning them tomorow.
I've check the compression and was fine on all fine. #1: 125 , #2 : 120, #3: 125, #4: 135. Not motor was not really hot so will need to redo a little bit later.
Anyway, look like a score on a nice KZ1000J project.
Will post some picture soon.
Thanks for your help
