Dynamo rotor
- Zapzuta
Dynamo rotor
08 Jun 2014 03:55
I removed the dynamo rotor today to replace the starter clutch and realized the woodruff key is missing. Is this a common problem? Sure this is the reason the starter doesn't work. Can I replace the key with one from the local hardware store?
- floivanus
Re: Dynamo rotor
08 Jun 2014 04:48
What bike is it? And not nessasarilly the reason it doesnt work, does the starter motor turn? Is the starter clutch grabbing etc?
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Zapzuta
Re: Dynamo rotor
08 Jun 2014 04:52 - 08 Jun 2014 04:54
76 kz900. Starter spins and gear spins when I push the starter button but the gear and rotor spins i think because the woodruff key is gone.( rotor and gear spins on crank. )
Last edit: 08 Jun 2014 04:54 by Zapzuta.
- floivanus
Re: Dynamo rotor
08 Jun 2014 06:05
Well put a woodruff key on it, and a little blue locktite on the end of the crank and the crank bolt and torque to spec (something like 20ft lbs torque iirc?)
Andrew
Andrew
