re build 1980 KZ1000
- KZ Rat
Re: re build 1980 KZ1000
09 Jun 2014 18:10
They are going to match the gears on the original cams- you would only have a problem if you used the new cams and the gears didn't match the crank gear.
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
- wireman
09 Jun 2014 20:03
How about a super size picture of that ltd KZ Rat? :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
- KZ Rat
09 Jun 2014 21:52
This one I have yet to get running -1980 ltd 29 smoothbores 4" over swingarm supposedly 1075cc with aftermarket cams. Rescued it off craigslist barter and threw my tins on it- was rolling some oil through the cylinders when the pic was taken. Not pretty but hopefully will be a runner soon.
Attachment 267300_4067355956856_1110144818_n.jpg not found
- LarryC
10 Jun 2014 03:56771000LTD wrote: What about the teeth on the crank?
Cam 30 / Crank 15
Cam 32 / Crank 16
Must use the correct match. .
Larry C.
- 771000LTD
14 Jun 2014 15:33
Just counted teeth on cam @ 32 on E- bay head
32 teeth on the original cam so i guess it s going to work.
Thanks again.
Thanks again.
