re build 1980 KZ1000
- 771000LTD
07 Jun 2014 18:01
Hello every one,
The question is can and should you put 1979 head on top of a 1980 engine ?
- 4TheKZ1000
Re: re build 1980 KZ1000
07 Jun 2014 18:05
why not 1979 and 1980 shared the same head on some engines. Is it a smog head?
- 771000LTD
07 Jun 2014 18:30
Dont know.just bought on e bay and there was no valve cover in pic.
Comes with the cams.
Attachment 1979head.jpg not found
- LarryC
The following user(s) said Thank You: 771000LTD
- StreetfighterKz
07 Jun 2014 18:53
The pic you posted is a SMOG head. You can see the four ports just above the spark plugs.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- 4TheKZ1000
07 Jun 2014 18:54 - 07 Jun 2014 19:14
yep a smog head. You will need a MKII or smog cover.
The red circles are the exhaust ports, for this reason the head is called a smog head or emission head.
On the head cover, you can see the front pockets.
It also has a square end not rounded.
Attachment IMG_4116800x480.jpg not found
Attachment bike011800x600.jpg not found
Attachment bike005800x428.jpg not found
Attachment bike059800x600.jpg not found
Last edit: 07 Jun 2014 19:14 by 4TheKZ1000.
- 771000LTD
07 Jun 2014 19:13
I got a cover from 1979 shaft that will work.Its black.
I guess I will need block off covers for the smog ports.
Tore the the bike all the way down ,re painted,powder coat stuff,bought new stuff as I was tearing it down to replace worn and broken stuff.
Now I just have to remember where it all goes. Pics will follow.
Thanks to all !
Thanks to all !
- 4TheKZ1000
07 Jun 2014 19:19Please Log in or Create an account to join the conversation.
- wireman
07 Jun 2014 19:53
use your original cams/sprockets to be safe
- LarryC
08 Jun 2014 04:12wireman wrote: use your original cams/sprockets to be safe
That's actually a valid point. Some 79 motors had 15 pin cranks with 30 tooth cam sprockets. 80's had 16/32.
Larry C.
- 4TheKZ1000
08 Jun 2014 07:29 - 08 Jun 2014 07:32LarryC wrote:wireman wrote: use your original cams/sprockets to be safe
____________________________________________________________________
Wow Larry and Jim agree on something........ :ohmy:
Last edit: 08 Jun 2014 07:32 by 4TheKZ1000.
- 771000LTD
