Throttle up issues
  • BIKEMECHANIC73
  • BIKEMECHANIC73's Avatar Topic Author
Throttle up issues
05 Jun 2014 17:16 - 05 Jun 2014 18:56
#635503
the issue I'm having is when accelerating through all the gears it throttles up, but then it seems to not pull as i increase the throttle in all the gears (same as if i would be sitting in neutral & throttling up) and doesn't seem to pull or speed up. What should I check first? My first thought was to change the oil & filter.... I have no idea what the guy before me had put in it.. Thanks!
Billy
1979 Kawasaki KZ650 B
They ain't related, but they Doobie Brothers..
Last edit: 05 Jun 2014 18:56 by BIKEMECHANIC73.
Re: Throttle up issues
05 Jun 2014 19:28
#635523
The ignition advancer might be stuck in idle position.
Is the clutch badly slipping?
Good Fortune! :)
The following user(s) said Thank You: BIKEMECHANIC73
05 Jun 2014 19:44
#635526
It sounds to me like your clutch is slipping. Use the instructions in the Kawasaki Service Manual to adjust it. Also, what oil is in the bike. If it is not JASO-MA compliant it could be making the clutch slip. If you change the oil filter and the oil using oil that is marked JASO-MA and adjust the clutch you may be ok without needing to pull things apart. Ed
  • BIKEMECHANIC73
06 Jun 2014 08:48
#635580
Hey Patton
No its not too bad. It starts accelerating just fine then stops pulling as much even if i crank it a bit.
  • BIKEMECHANIC73
06 Jun 2014 08:57
#635582
Hey Ed,
That was actually my first instinct. The guy I bought it from seemed a few bricks short of a wall, so I have no idea what he put in & how long he ran it like that. I'm going to change the oil & filter this weekend & adjust accordingly.
Thanks again!
