Houston we have a problem
- Beaner242
05 Jun 2014 16:44
Bought new valve cover gasket and am checking the valves while I have it off. first one was right on at .05mm according to manual. the rest are all tight, as in cant get a .04mm gauge in there and that is the smallest gauge I have. Whats the problems im facing with the valves to tight?
1982 KZ1000K LTD Chopper
- Nebr_Rex
Re: Houston we have a problem
05 Jun 2014 17:45
Reshim, your not doing your engine any good.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Beaner242
05 Jun 2014 18:14
do I need the shim removal tool or is there a way to do it without it?
05 Jun 2014 19:31
Do a search for batwing, which should produce some informative threads.
- kaw-a-holic
05 Jun 2014 20:19
No eBay APP ID and/or Cert ID defined in Kunena configurationYou have to buy the shims any, the tool is cheap.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- bountyhunter
05 Jun 2014 20:47Burn a valve seat = head is destroyedBeaner242 wrote: Bought new valve cover gasket and am checking the valves while I have it off. first one was right on at .05mm according to manual. the rest are all tight, as in cant get a .04mm gauge in there and that is the smallest gauge I have. Whats the problems im facing with the valves to tight?
- Beaner242
05 Jun 2014 21:01
thanks Kawaholic and bounty. Ive been on Z1 and they have that tool for 8 bucks. looks like that's the way ill be going. Now to figure out which shims to get.
- kaw-a-holic
05 Jun 2014 22:02
Do you have a service manual. It tells you how to figure out the shims needed based on what size you have and +/- space at the shim. What year and model to you have?
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- Haybus
- Big Al
05 Jun 2014 22:26
I couldn't bring myself to spend $8 + $7 for shipping for a bent screwdriver and a flat piece of metal. If I had been purchasing something else at the time, then no problem with $8. Kind of hard to figure out what shims you need if you have some no gap situations. Made my own batwing tool from 0.125" aluminum and used a plain old flat screwdriver. Works perfectly. Suggest diagramming the shims and gaps by location, then look up the new shims on the chart and write them on the diagram. You'll probably be able to move a shim or two to new locations. I adjusted 6 valves but only bought 3 shims.
Alan
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- Beaner242
05 Jun 2014 22:36
82 1000 ltd. I was wondering if it wouldn't be easier to pull the cam holders off to get the shims out just to figure out which ones I need?
- bountyhunter
06 Jun 2014 00:40
Make sure you have some calipers so you can mic the shim thickness. Some have the number rubbed off and some are marked off.
- bountyhunter
06 Jun 2014 00:43Some shops did it that way. It takes longer to keep R+R the camshafts, but the real danger is how easy it is to strip the cam cap bolts from repeated going in and out.Beaner242 wrote: 82 1000 ltd. I was wondering if it wouldn't be easier to pull the cam holders off to get the shims out just to figure out which ones I need?
