KZ 1300 Head Work
  • LarryC
  • LarryC's Avatar
Re: KZ 1300 Head Work
07 Jun 2014 05:17 - 07 Jun 2014 05:19
#635640
Tyler,
Measure the valves when you get it apart. The exhaust look pretty large in that picture. I have no doubt there's power to be pulled out of those heads. Some bowl work and throat sizing with a good valve job will likely wake up the ponies......What are the cam specs?
Larry C.
Last edit: 07 Jun 2014 05:19 by LarryC.
  • Tyler
  • Tyler's Avatar Topic Author
07 Jun 2014 10:09 - 07 Jun 2014 10:11
#635681
Larry, I haven't measured the specifics on my engine yet but from my manual and specs on available parts this is what I know.
Bore: 62mm
Stroke: 71mm
CR: 9.9 to 1
Head Chamber Volume: 27.1 to 27.9cc
Ex. Valve Size: 29.5mm
In. Valve Size: 34.5mm
This engine runs a domed piston. Peak torque @ 6,500 Peak Hp @ 8,000rpm (according to the manual anyways)
And some cam info from Megacycle
Attachment kz1300cams.jpg not found
"74 Yamaha DT 400 Enduro
Last edit: 07 Jun 2014 10:11 by Tyler.
  • LarryC
  • LarryC's Avatar
07 Jun 2014 19:04
#635714
Intakes are 55% of the bore diameter so that's plenty. The exhausts looked bigger than they actually are. Those long runners are great torque makers but probably hurt peak flow somewhat. That 490-70 grind would make a nice drop in. L/D ratio would be better than same lift for a KZ1000. If you're not putting pistons in it, that's the one you want.
Larry C.
  • Tyler
07 Jun 2014 20:04
#635731
I am considering a 64mm piston, just a bit shallower than stock, not clearanced for a big cam.Supposed to be close to stock CR. Any bigger and I need to put overbore sleeves in the block, not something I want to get into. Not many carb options, so Im sticking with the stock set-up. Three, two barrel carbs, BS style Mikunis 32mm per barrel. Not gonna mess with a DFI conversion.
