Rotor and gear
- Zapzuta
Rotor and gear
04 Jun 2014 17:19
Does the gear and the rotor supposed to move freely of each other and the crank?
- azman857
Re: Rotor and gear
04 Jun 2014 22:37
Would help if you would tell us what model we are looking at? You can list that in your signature.
- zed1015
Re: Rotor and gear
05 Jun 2014 07:33
With the crank stationary (not moving) the starter gear should rotate freely when turned clockwise and lock when rotated anticlockwise.
The Rotor should be locked to the crank and only rotate with the crank.
Re: Rotor and gear
05 Jun 2014 08:35azman857 wrote: Would help if you would tell us what model we are looking at? You can list that in your signature.
- zed1015
Re: Rotor and gear
05 Jun 2014 10:44
There's a picture of the engine attached in the original post.
Clearly a Z900/1000.
