sat for 2 years outside. what needs done first?
  • kingjoker74
  • kingjoker74's Avatar Topic Author
23 May 2014 07:33
#633628
I got a 79 KZ 1000 LTD the other day that ran when it was parked but sat outside for 2 years. What do I need to check first. Never had a bike that sat any time outside and I don't have a lot of mechanical knowledge besides basic maintenance.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: sat for 2 years outside. what needs done first?
23 May 2014 11:11 - 23 May 2014 11:12
#633651
Not necessarily what needs to be done first, you need to do a bunch of things: change the oil and filter, squirt oil down the cylinders and turn the engine over with the kicker, slowly, a few times. Install new plugs, clean carbs, remove air filter and look for mouse nests, same with the exhaust. Lube cables. Unplug all the terminals, clean them and spray down with WD40 then use some dielectric grease. New battery (yes you need it to run properly) and you should be able to start it up. Iwouldn't even try running the bike without doing all those things thoroughly. It will save time later on if it's not running right, you can cross all that stuff off the list.
Anything after that is all chassis: tires, service suspension and swingarm pivot, etc.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 23 May 2014 11:12 by Kidkawie.
