Stock Exhaust or Aftermarket Header?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
21 May 2014 20:31
#633381
77' KZ1000A right side muffler damaged ( probably crashed on right side ). If I choose to restore to stock, are there other years of mufflers from the KZ1000 line-up that will fit? Also toying with the idea of a header. Vance and Hines or Kerker? Pros and Cons of both if anyone has had any experience with these. Any help/advice would be greatly appreciated!
77' KZ1000A
  • bountyhunter
  • bountyhunter's Avatar
Re: Stock Exhaust or Aftermarket Header?
21 May 2014 21:40
#633387
I kind of wish mine had the original pipes, but they do die as a result of being crashed. A good original pipe is really pricey if you can find it.
22 May 2014 05:18
#633414
According to Kawasaki.com the 1977 KZ1000-A1 uses the same right side muffler as the 1978 KZ1000-A2 and 1978 KZ1000-A2A. Ed
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
22 May 2014 07:36
#633425
kzdcw wrote: Also toying with the idea of a header. Vance and Hines or Kerker? Pros and Cons of both if anyone has had any experience with these. Any help/advice would be greatly appreciated!
Many folks have had great success with the motogpwerks pipe, including myself. Head and shoulders better than V/H or Kerker for similar money.
  • kzdcw
  • 77' KZ1000A
22 May 2014 23:02
#633589
Looks too new school with it's small muffler design. What about filter and drain plug clearance?
77' KZ1000A
  • slayer61
  • slayer61's Avatar
23 May 2014 07:36 - 23 May 2014 07:37
#633630
kzdcw wrote: Looks too new school with it's small muffler design. What about filter and drain plug clearance?
I can't speak to clearance on KZ. I have a race version on a GS and it's all spring mounted so it's a snap to drop the pipe for oil changes ;)
Last edit: 23 May 2014 07:37 by slayer61.
  • kzdcw
  • 77' KZ1000A
23 May 2014 18:43
#633710
Since finding a stock exhaust replacement is probably as scares as hens teeth, maybe I should point my attention to a header. I'm sure plenty of you guys are using either the Vance and Hines or the Kerker. But like to hear pro and cons on these? ANYONE like to take a stab at it ???
77' KZ1000A
  • kaw-a-holic
  • kaw-a-holic's Avatar
23 May 2014 23:26
#633733
That's what I bought can't beat the craftsmanship for the money very well built. Can't wait for my bike to be put back together so I can hear it. I know the You Tube videos do not do it justice.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • kaw-a-holic
23 May 2014 23:37
#633734
He also makes one with a bigger can. Oil filter is not an issue as mentioned before, it's spring loaded and come right off. I used to have a Kerker sidewinder, I was never able to change the oil without getting some on it. If I had to pull the header off I always had to replace the exhaust gaskets and "f" around with the exhaust collars and keepers. With the Motogpwerks that is not an issue. The inverted cone on the Kerker was always coming loose. I got on the throttle heavy one day and blasted it off never found it. I custom made a cone and made my own baffle to get the sound I wanted, sounded nice and preformed well but I would never pay $700 for a new one. I found mine on eBay for $150 or something close to that. The Motogpwerks is 200 times the craftsmanship. That's my .02
Jon
1977 KZ1000a1
Mesa, AZ
