Ticking noise
- nickleo373
Ticking noise
21 May 2014 14:42
Hey everyone
Last year my KZ550 would make a ticking noise while it was idling but over the winter I adjusted the float height and did a few other things and the noise stopped. Yesterday after I turned the bike on I noticed the noise was back. It seems to go away when the bike is going more than 35 mph. I can't figure out where the tick can be coming from. Any ideas?
1981 KZ550C LTD
"If you ain't first, you're last"
- bountyhunter
Re: Ticking noise
21 May 2014 19:24
A tick is usually a loose valve clearance. Some ticking noise is normal, if it's really loud it's probably a valve.
- roy-b-boy-b
Re: Ticking noise
21 May 2014 19:26
Could be oil is slow getting to top of engine. If the bike has a lot of miles the oil pump screen might be sitting in sludge.
- nickleo373
Re: Ticking noise
22 May 2014 13:41
Thanks for the replies. I narrowed it down to the cam closest to the front of the bike. It seems to be an intermittent problem. The bike only has 7000 original miles on it so I don't think anything is clogged up.
1981 KZ550C LTD
- Kidkawie
- I bleed premix
Re: Ticking noise
22 May 2014 14:01
Cam chain adjustment?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- nickleo373
Re: Ticking noise
22 May 2014 17:33
I got a video earlier
1981 KZ550C LTD
- pscycle
- MMMMHMMMM
Re: Ticking noise
22 May 2014 22:18 - 22 May 2014 22:19
Cam Chain may be it also a very small leak in you exhaust clamp area creates sounds look for little tiny puffs of smoke up front by the clamps. may have a nut vibrating loose.
pscycle927
Last edit: 22 May 2014 22:19 by pscycle.
- nickleo373
Re: Ticking noise
23 May 2014 13:45
I tightened up all the exhaust bolts today and the noise is still there. I'm thinking it's the cam chain. Anyone know how to tighten it up so it stops slapping the valve cover?
1981 KZ550C LTD
- Cynjut
Re: Ticking noise
23 May 2014 13:55 - 23 May 2014 13:56
Your engine has an automatic cam chain tensioner, so if the cam chain is out of spec, you might need to consider either replacing it with a manual cam chain tensioner or installing a new cam chain.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Last edit: 23 May 2014 13:56 by Cynjut.
