Help, I've lost my part reference website!
- daveo
19 May 2014 17:56
It's gone. The new site only goes back to 1984...now what? :ohmy:
Please...I need a reliable new (old) site-link for KZ part numbers and diagrams model-specific.
1982 KZ1100-A2/1170 sleeper 😀
Re: Help, I've lost my part reference website!
19 May 2014 17:59
Go to Kawasaki.com. On left side put cursor over "Owner Information" then on drop down menu click on "Parts Diagrams." The click "Continue" next to "Motorcycles" and click on model/year/etc. on drop down. Once you get the list of parts for your bike you can click on the category of parts - such as "Air Cleaner" and you will see a diagram of all the parts for that category. Then when you click on an actual part number on the list under the diagram it will say if the Item Status is "Active." If it is "Active" Kawasaki still sells the part through dealers. Also, at that little page you can click on the yellow highlighted question mark for a cross reference of which bikes share that part or click on the red highlighted S to see earlier part numbers for the same part.
If you want to change bike models you can enter the new model at the top. Also, you can put in just the first part of the model (i.e. KZ650) and it will list all the years and sub models. You also can put in a part number up top and switch the word "MODEL" to "PART NUMBER" using the little drop down in that box. If you do that it will show all the models that part is used on.
- daveo
19 May 2014 18:04
A profuse Thank you!
20 May 2014 06:31
Partzilla is fairly easy to use & kinda faster than Kawasaki.com.
However, for the cross-reference, double check partzilla's info against the Kaw site.
20 May 2014 18:13
kawasaki.com includes parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for further help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
