Boring to...1075 or higher?
Re: Boring to...1075 or higher?
16 May 2014 17:36
- racer54
17 May 2014 05:40
Whew....sure gets exciting around here at times but here is my take...
1075 can be bored into stock 1015 sleeves. Good little all-around motor. 1015 sleeves can be bored out to 1105 too. Some say its ok but it does make the sleeves on the thin side. Have heard some work great while others have told me sometimes the thin cylinder walls will go out-of -round. Larger then 1105 you will need bigger sleeves bored into the stock block. This means the upper cases have to be bored out to accept the larger liners. The newer bigger liners will go up to 1260 but 1200 is considered the best size to go. 1230 and 1260 size motors leave liners on the thin size. AGain...some have used them on the street with no problems while some have had problems.
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
17 May 2014 21:19The reason?gearheadmm wrote: All of my street turbo bike were 1075.
7-10lbs on the street, 30lbs of boost at the track, no problem.
Everyone I ever talked to about KZs told me that was the limit on a stock 1015 block.
I've been racing KZs for over 20 yrs and I pick everyone"s brain every chance I get.
Including Billdo Hahne (worked for him for 3yrs), Kent Stotz, Brian Bennet, Geoff Pollard, George Brice, Elton Fish (worked for him for 2-3 yrs), and quite a few other funnybike, shootout, and sportsman racers.
I'm betting Larry might have told a few of them that.
That being said I think we can lay this one to rest.
Why push it.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- DobbinsCMA
19 May 2014 13:26
Well that was...interesting. Im going 1075. Having them done for 47.90 a hole. Also what about pistons? MTC has good ones but what do I want with compression? 474 seems the price for them.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- turboking
19 May 2014 14:08
I agree with LC, 1075 cc is the limit for me on a 1015 cc stock liner block :blink: .....stock liners are way too thin at the bottom......... I've seen 73 mm/1105 cc break at the bottom in a stock liner 1015 block or have heat/ blow by issues in a turbo........ bigger liners require boring the upper case. :S MY .02 :woohoo:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- zed1015
19 May 2014 14:11
Either MTC or Wiseco are a good choice.
Pitstop does MTC but supplies buttons instead of circlips.
I prefer circlips for the road but you takes your choice.
Both makes state a 10.25 - 1 static comp for the basic road /performance piston which is where you want to be for a quick reliable no fuss road bike and they work just as well as a basic piston upgrade or part of a planned tuning program.
19 May 2014 15:29
If it were me I would ship my block to Joe at Pitstop and let him fit each piston to its hole and he also gaps and installs the rings. Who ever does it needs to bore the block for the individual pistons and not just bore to a standard number. I had Joe do work for me with MTC pistons and the job was perfect.
- gearheadmm
19 May 2014 15:54 - 19 May 2014 15:58
I have used buttons on the street for 8yrs, no problem on two different engines.
I lost a clip on an H-1 2 stroke, (not my work) disaster.
Last time I tried MTC 1075 9to1 weren't available so I went with Wiseco 9to1 for the turbo.
Last edit: 19 May 2014 15:58 by gearheadmm.
- DobbinsCMA
19 May 2014 17:54
They have to be bored to the piston? Why wouldn't boring to the size of the piston need to be done? i mean for 479 dollars i would hope that they are within .001? I could see a machine shop screwing up but If i give them the specs and they mess up, they are going to buy me a new cylinder head. Idk What do you all think about drilling to the piston not the specs?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
19 May 2014 18:35DobbinsCMA wrote: They have to be bored to the piston? Why wouldn't boring to the size of the piston need to be done? i mean for 479 dollars i would hope that they are within .001? I could see a machine shop screwing up but If i give them the specs and they mess up, they are going to buy me a new cylinder head. Idk What do you all think about drilling to the piston not the specs?
Pistons can vary in size. I suggest you e mail Joe Hopper at Pitstop and ask about this and how he makes sure you get optimum piston to wall fit. He is a perfectionist and that's how I like my work done.
The following user(s) said Thank You: PLUMMEN
- baldy110
19 May 2014 18:35
Yes the cylinders should be bored to each individual piston. The reason for that is due to production differences the pistons are not all identical so the machine shop has to custom fit each cylinder to each piston using the proper clearances provided by the piston manufacturer. A good machine shop will ask for the pistons for the boring and honing process.
Now having said that in the past I have installed used pistons, rings and not done anything to them and they have worked well.
