kick start seems stuck.
  • seimser
  • seimser's Avatar Topic Author
15 May 2014 13:38
#632568
I have a Kawasaki 750 twin Ltd. And a wierd problem.. When i take apart the left side of the engine and off whit the magnet and starter clutch, the kick goes easy as it should. However when i put it together and the more i tighten the big bolt for the magnet going in too the shaft. The harder it gets to kick it over. What would be the problem i wonder ?
  • floivanus
  • floivanus's Avatar
Re: kick start seems stuck.
15 May 2014 18:43
#632603
The magnet is your flywheel/rotor and it sounds like it has been tightened up too much sometime before, or not tight enough and wallered out so the interference fit is too sloppy now, tightening it up locks the flywheel/rotor/starter clutch against the engine case and keeps the crank from spinning, time for some new parts
Past; 78 kz1000, 83 kz550
Andrew
  • seimser
16 May 2014 08:53
#632637
So a new rotor magnet is what i should look for ? Dö you know the tourqe settings for the bolt ?
  • pete greek1
  • pete greek1's Avatar
16 May 2014 10:02
#632646
First thing you should do is, get A KAWASAKI service or workshop manual for your year & model specific bike
  • seimser
16 May 2014 12:34
#632660
Done. Bolt should set to 12-14 kg / m. But is it the rotor that needs changing ? Or pherhaps rotor and starter clutch ?
  • floivanus
16 May 2014 13:21
#632665
The rotor/flywheel magnet has a tapered fit to it, if the hole is worn out, that piece definately needs replacing, you need to watch the torque specs and use loctite where needed
Andrew
  • seimser
16 May 2014 14:24
#632669
Sorry my English is a bit off. Tapered ? Meaning the steel plate between the starter cluch and the "big" starter wheel ? Or am i totaly lost ?
