starter question
  • flexvatos
  • flexvatos's Avatar Topic Author
starter question
14 May 2014 07:09
#632371
Will a starter from a 83 kz 1000 fit on my 83 kz750twin
Re: starter question
14 May 2014 07:39
#632377
No. Or at least not without significant modifications (with enough money I guess almost anything can be done). Compare the two in the diagram below and you'll see how different they are. Ed
Attachment 00008_2014-05-14.jpg not found
  • Topper
  • Topper's Avatar
14 May 2014 08:22
#632382
Is your current starter totally dead? There are cheap rebuild kits available that are pretty easy to do.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • flexvatos
14 May 2014 17:54
#632481
I found a starter on ebay it's from a 82 kz750 spectre will that fit on the 83 kz750twin,
14 May 2014 18:27
#632488
No.
You have a Kawasaki KZ750 2 cylinder bike (a twin). You need to ether rebuild the starter you have as Topper recommended or buy a starter for a KZ750 2 cylinder bike (a twin). The KZ750 Spectre is a 4 cylinder motorcycle and it uses a different starter than the KZ750 2 cylinder motorcycles. Below is a list of motorcycles that use the same starter part number. Each one is a KZ750 twin. Ed
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
KZ750-K1 (LTD Belt) (1983)
KZ750-K2 (CANADA ONLY) (1984)
KZ750-M1 (CSR Twin) (1982)
The following user(s) said Thank You: flexvatos
14 May 2014 18:33
#632493
Here is a place that sells remanufactured starters:
www.motorcityreman.com/620-079.html
