Base Gasket Replacement
- rhityx02
13 May 2014 12:45
Hello Fellow KZ Friends,
I am going to be tearing down my 1977 KZ 650 B1 to repair a leaking base gasket. I am going to be ordering my gaskets and O-rings from Z1. The top end kit has the two 92055-111(oval) in the kit and I am also getting the two 92055-101 (10mm) and two 92055-099 (8.8mm) and the one I need for the tachometer drive. I see in my one manuals that there are four large what I am going to call O-rings that look like they go around the bottom of the cylinders to the top of the block…what are these…will I need to get them and if so what are the part numbers? I also would like to know if there is anything else I am missing. I want to order everything all at once so I can do this whole thing at one time so it will have the least impact on riding time. Just getting into good riding season and I can’t stand to be down waiting to order parts that I missed or forgot.
1977 KZ650 B1
Ty
Ty
Re: Base Gasket Replacement
13 May 2014 13:05 - 13 May 2014 13:07
Excellent question about the o-rings! They are a mystery part that was included in all the original KZ650-B1 and KZ650-C1 parts diagrams and then (here's the mystery part) they disappeared from later parts diagrams. They are part number 92055-089 - O-ring 67mm (see parts diagram below). I guess later bikes didn't have them, but here's my suggestion - buy 4 of them and if your engine has them replace them with the 4 new ones. (At least that's my plan if I ever rebuild mine, so I now have 4 in my parts bin.) Here's a place that has them in New Old Stock for $1 each (see link). Ed
www.nwvintagecycleparts.com/search-resul...arch.x=7&search.y=12
Attachment IMG_0481z.jpg not found
Attachment IMG_0482z.jpg not found
Last edit: 13 May 2014 13:07 by 650ed.
- rhityx02
13 May 2014 20:17
Thanks Ed...I could not find out what they were. Great help. Thanks.
1977 KZ650 B1
Ty
Ty
- rhityx02
29 May 2014 12:38
I now have these O-rings.
I test fitted them last night and I and not sure what the O-rings are supposed to seal. If I slide the O-rings over the cylinders and let them rest on the surface; there is an interference with the base gasket and O-rings. There seems to be a groove that the O-rings can fit into between the sleeves and the aluminum but it is going to be a very tight fit. If they do fit into this groove…what are they sealing, because after they are in the groove they are below the sealing surface?
1977 KZ650 B1
Ty
Ty
- baldy110
29 May 2014 13:12
They don't do anything, I always leave them out.
