kz200 engine noise
- gunner
kz200 engine noise
09 May 2014 19:34
So I have (I think) gotten this '78 kz200 running pretty well. I do still have a bit of a leak at the head gasket, but haven't taken the head off to replace it yet.
I have cleaned the carb, adjusted the timing, points, cam chain etc. but am having a hard time knowing if the engine sound is "normal" (this is my first bike since I was a teen!). There seems to be a consistent ticking sort of noise, almost like a rattle. It increases as the engine revs.
I assumed at first it was the valve clearance, but have adjusted them to spec. and there doesn't seem to be a difference.
Wondering if this is just the sound of the little kz200, or if it may be valve seat? rocker arms? piston noise?
Anyone have any ideas before I take it all apart?
Thanks
Thanks
KZ200
Toronto
Toronto
- gunner
Re: kz200 engine noise
12 May 2014 17:56
I took some video to try to get a read on the sound ... have tried to compare it to youtube videos, but still unsure. Any thoughts would be appreciated.
Attachment IMG_2768.mov not found
KZ200
Toronto
Toronto
- moneypit
13 May 2014 13:29
Dont really know that bike, head gasket leaking could make noise, but could also be an exhaust leak. Retorqe the head to spec. when dead cold, may help the head gasket leak. Have you had the pipe off?
If so make sure the crush washer is replaced. Good luck
2-76 kz900
St Paul MN
St Paul MN
The following user(s) said Thank You: gunner
- gunner
13 May 2014 18:36
Thanks money - I did have the pipe off and had to make a new split collar as it was leaking pretty badly. I did put a new gasket in - a copper one, replacing the original, a sort of felt-like material?
I will also try to torque the head before I take it off.
Thanks
Thanks
KZ200
Toronto
Toronto
- 4TheKZ1000
- gunner
13 May 2014 18:45 - 13 May 2014 18:46
totally! his wheel must be out of alignment too!
Ha!
Ha!
KZ200
Toronto
Toronto
Last edit: 13 May 2014 18:46 by gunner.
- xwolfkvltx
25 Nov 2014 06:26
Hi, just wondering if you found out what the noise was? I just had mine rebuilt and it's making the same noise. Thanks
- gunner
25 Nov 2014 06:50
Ya - the main issue was the split collar around the header - the one on my bike was not stock nor well made - it wasn't holding tight or holding the gasket tight.
KZ200
Toronto
Toronto
- xwolfkvltx
25 Nov 2014 07:13
Really?? Wow I hope mine turns out to be just that, will give it a shot tomorrow. Thanks
- gunner
25 Nov 2014 07:18
Seems to be - rode all season with no problems ... it certainly doesn't rumble but the ticking or rattling is much better.
KZ200
Toronto
Toronto
