firing order
- zoli1961
09 May 2014 02:09 #631896
by zoli1961
firing order was created by zoli1961
1981 kAWASAKI Zr 500 firing order Because the cylinder is not going as 1-3.But there is a spark of the candles.
It would be nice one big help.
- Thank you received: 2098
09 May 2014 05:01 #631905
by Patton
Hello, zoli1961, and WELCOME to KZr!
Am unfamiliar with "Zr 500" and uncertain as to exactly which 1981 Kawasaki model is being asked about.
Kawasaki's 1981 four cylinder models usually have 2 ignition coils, one of which should be connected to the outside spark plugs, and the other coil connected to the inside spark plugs.
Replied by Patton on topic firing order
zoli1961 wrote: 1981 kAWASAKI Zr 500 firing order Because the cylinder is not going as 1-3.But there is a spark of the candles.
- Thank you received: 1656
09 May 2014 06:00 - 09 May 2014 06:05 #631909
by martin_csr
Replied by martin_csr on topic firing order
From an internet search the Z500 is apparently a scaled down version of the Z1R. neato.
Here's a wiring diagram for the KZ500-B1. I have no idea if the B1 is the same as yours. home.comcast.net/~loudgpz -->>> the link's main page is here -->>> loudhvx - motorcycle stuff
Here's the way the stuff is on an 81 KZ650. Yours is probably the same, but your coils could be on the reverse sides of the frame from the 650 &/or the igniter wire colors may be reversed as well.
Firing order = 1-2-4-3.
Right side coil = #1 & #4 spark plug wires and Black & Red igniter wires.
Left side coil. = #2 & #3 spark plug wires and Green & Red igniter wires
Last edit: 09 May 2014 06:05 by martin_csr.
- Cynjut
- Thank you received: 26
09 May 2014 08:42 #631917
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic firing order
Incredibly pedantic mode on:
Because of the "wasted spark" system we use, the firing order is 1/4 - 2/3 - 1/4 - 2/3 (1 and 4, then 2 and 3).
Ignition stroke order (set by the valves) is 1 - 2 - 4 - 3 .
I know it's an ridiculously particular point, but it took me a couple of weeks farting around with the timing to get it straight back when I installed the Dyna-S on the A1.
Thanks for your attention.
1977 KZ-1000 A1
