Cylinder hight
- The Banned
Cylinder hight
08 May 2014 22:45
im going to install my Wiseco 1197cc this week but after some measuring I found out that the cylinder was 1.3mm lower than a 'stock' cylinder.........
Do i just mount everything as normal or would people mount an extra lower cylinder gasket??
Anyone knowing what the minimum hight is??
Im running the K410 cams as well
- Powerstroke_fan
Re: Cylinder hight
09 May 2014 04:41
I think youll need to run a spacer to get it back to proper deck height.
1977 KZ 1000 work in progress
- zed1015
Re: Cylinder hight
09 May 2014 08:54 - 09 May 2014 08:57
Carefully dry build the top end without any gaskets and measure the squish with some solder.
Be careful when rotating the crank of marking the piston crowns if they come up high enough to contact the head.
If you have any sort of clearance the squashed solder can the measured to tell you how much you have and then you can work out what arrangement of gaskets and spacers are needed to get the correct clearance and compression.
If you have no clearance then you will need to start with some gaskets of known thickness installed and go from there.
Last edit: 09 May 2014 08:57 by zed1015.
The following user(s) said Thank You: PLUMMEN
- The Banned
Re: Cylinder hight
11 May 2014 10:10
Thank you...
how much clearance should there be between the pistons and the valves??
Re: Cylinder hight
12 May 2014 07:59 - 12 May 2014 07:59
Piston to valve clearance ( minimum ):
KZ / Z1 - 0.050 Int., 0.075 Ex. (in inches)
stolen from here,
www.aperaceparts.com/cope.html
hope this helps,
stolen from here,
hope this helps,
Last edit: 12 May 2014 07:59 by 531blackbanshee.
- The Banned
Re: Cylinder hight
12 May 2014 11:02
happy to help.
sounds like you should make a folder for this bike to keep all your info in order
