2 dead cylinders
  • kz900er
  • kz900er's Avatar Topic Author
2 dead cylinders
08 May 2014 10:43
#631819
Took my '76 KZ900 out yesterday and in about 20 miles the #2 & #3 cylinders went dead, #1 & #4 plugs are gray to white. It has been changed to electronic ignition in the past. Thanks for any ideas
  • zed1015
  • zed1015's Avatar
Re: 2 dead cylinders
08 May 2014 10:59
#631820
Most likely the coil, associated wiring or ign pick-up that serves cyls 2 and 3 .
Swapping coils will confirm a dodgy one if the fault moves to 1-4 or rule it out if no change.
If no change then look at the wiring and then the ign pick-ups.
Which part of the plug is looking grey/white.
  • kz900er
08 May 2014 11:10
#631823
The firing ends are grey/white, doing good. Thanks
08 May 2014 16:48
#631856
kz900er wrote: Took my '76 KZ900 out yesterday and in about 20 miles the #2 & #3 cylinders went dead, #1 & #4 plugs are gray to white. It has been changed to electronic ignition in the past. Thanks for any ideas
What do #2 and #3 plugs look like?
Is one of them obviously fouled?
While a weak ignition may well be the culprit, another possibility is when a too high fuel level causes an over-rich condition which fouls a plug whereby both plugs quit firing.
Good Fortune! :)
