KZ400 Carb Bolt Disaster
- ShaCvet
07 May 2014 20:58
Short story: Needed to replace carb boots...tried everything....then after my father tried successfully removed one with notching and hammering to turn it, he moves on....then this happened! Oh and not to mention one is broken off in the head too. Is this even fixable?
Attachment 20140507_172808.jpg not found
1979 KZ400 B2 fully restored and powder coated.
- ShaCvet
Re: KZ400 Carb Bolt Disaster
07 May 2014 20:59
Oh and there is only 6000k miles on this engine!
- floivanus
07 May 2014 21:23
Would suggest finnesse and heat with a penetrating fluid next time.
Yes it's fixable, would need to take off head and get it tig welded inside AND out, smoothed out and re-assembled, or just get a new head for it
Past; 78 kz1000, 83 kz550
Andrew
Andrew
08 May 2014 05:12 - 08 May 2014 05:13
Thank you for the photo. It so clearly demonstrates what I and others have warned folks about many times on this website - when removing stubborn fasteners excessive force is never necessary and will very often cause the owner excessive pain. Simply soaking the fastener with Kroil for 2 or 3 days and using the correct tool prevents such damage every time. The bad part is that you learned this lesson the hard way; it's a shame you didn't ask advice before damaging your bike. Ed
Last edit: 08 May 2014 05:13 by 650ed.
- ShaCvet
09 May 2014 15:27
Thankfully I know a machinist and he tig welded it right back up!
- undiablo
09 May 2014 16:52
A good TIG jedi will fix it.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- ThatGPzGuy
10 May 2014 05:28
I'm glad it could be saved.
Heat, penetrating oil and patience will work just about every time.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Nebr_Rex
10 May 2014 07:36
Also an impact driver.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
