cam bearing clearance
- krazinite2003
04 May 2014 13:21
can i check cam bearing clearance with plastigage? and valve clearance with the head removed from the engine on a 82 gpz 750
i have two 1983 kz750 L3
- 4TheKZ1000
Re: cam bearing clearance
04 May 2014 14:17
Yes on cam bearings. I use the green plastic-gauge.
On the other, why?
On the other, why?
- krazinite2003
04 May 2014 14:25
i have the top end apart to change cams oh i should mention that this is a spare motor that i want to put into my L3 i have the pistons off as well not really wanting to put the top end back together rite this moment i just figured that it would be easier to do the checks while head is off
- baldy110
04 May 2014 18:52 - 04 May 2014 18:53
The 82 gpz750 does not have cam bearings.
Last edit: 04 May 2014 18:53 by baldy110.
- KZB2 650
07 May 2014 04:28
I got a 1980 KZ750 cam set for my KZ650 on Ebay and checked them out with Plastigage I got 2 intakes at .003, 2 were at .0035 and all the exaust were right at .004 so I was good to go. Like Baldy said there are no bearings so it was good to see the heads still holding up fine.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- 80B4
07 May 2014 07:25
When you use the Plastigage, remember to have all of the valves removed from the head or you will get a false reading.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- steell
07 May 2014 21:25KZB2 650 wrote: I got a 1980 KZ750 cam set for my KZ650 on Ebay and checked them out with Plastigage I got 2 intakes at .003, 2 were at .0035 and all the exaust were right at .004 so I was good to go. Like Baldy said there are no bearings so it was good to see the heads still holding up fine.
You checked the valve clearance with Plastigage?
- KZB2 650
08 May 2014 04:52
No Steele I meant the cam bearing and head bearing clearances. No grooves either everything was nice and smooth.
After 500 miles and now at 650 miles (after the rebuild) I had two slightly tight ex valves at .005 and the other at .0035 so I shimmed them out to around .0065 to .007 and now all 8 are right at that clearance. Shouldn't have to check or remove those darn cams for a good long time now. :woohoo:
1978 KZ650 b-2
