Tach Oil Seal....which direction?
  • bLodi
  • bLodi's Avatar Topic Author
02 May 2014 17:45
#631155
Quick question. Which way should the oil seal for the tach drive cable go? Should the side with the spring go in or out?
Thanks!
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
Re: Tach Oil Seal....which direction?
02 May 2014 18:00
#631158
The side with the spring should face the engine, the smooth side faces out. Ed
  • bLodi
02 May 2014 20:13
#631167
That's what I thought, had it backwards. Thank you!
www.blodisign.com
\\\\\\\'74 Z1
