Exhaust options?
  • Bonestock
  • Bonestock's Avatar Topic Author
Exhaust options?
30 Apr 2014 13:04
#630936
Anybody know of some alternative exhaust makers (Euro maybe?).
I've got a stockpile of vintage roadrace parts for the 78 KZ!000A2 & I really like the look of some of the pipes I see that are a bit different than the usual Kerker/V&H.
The old Yoshi/Bassani pipes are almost impossible to find in good condition.....anybody know of other makers that cover our old KZs?
Old Skool ~
  • tattooDan
  • tattooDan's Avatar
Re: Exhaust options?
30 Apr 2014 22:37
#630992
I just bought one of these for my 80 shaft,I haven't put it on yet,but I really love the vintage yoshi look & the stainless,he only has one left for the year.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&v...tr&item=121321662612
thanks to slayer61 for this tip www.kzrider.com/forum/2-engine/593452-so...r-my-80-kz1000-shaft
1980 KZ1000E ST/SHAFT
  • TexasKZ
  • TexasKZ's Avatar
01 May 2014 00:52
#630998
Last I heard, Jemco in Houston will make them on request, though the KZ system is no longer listed on their website.
  • Bonestock
01 May 2014 08:02
#631027
Thanks, Dan,,,,those are nice!
I'll look into the Jemcos, Tex....
Old Skool ~
  • MTH76
  • MTH76's Avatar
01 May 2014 09:24
#631030
I also bought one of the Motogpwerks pipe.
I love the way it looks and sounds, the only thing I mind is that you need to remove it to change the oil filter.
Do yourself a favor and change your oil before you put it on.
It sounds like a modern sport bike.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
  • Bonestock
01 May 2014 09:34
#631031
MTH....did you order a "Z version" or modify a Z1R pipe?
I'm not sure if the canister/rear hanger is in the same location on the two bikes....
Old Skool ~
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
02 May 2014 07:56
#631118
TexasKZ wrote: Last I heard, Jemco in Houston will make them on request, though the KZ system is no longer listed on their website.
Jemco make a good solid pipe. I've had them on my flattrackers for years. They are all steel construction but used to offer a "quieter" aluminum can as an option.
My racer with the aluminum can.
[IMG
My wife's bike with the steel can.
[IMG
  • Bonestock
02 May 2014 09:22
#631122
Nice! Those look like the old TT500 motors. I had both a TT500 and a 600...gobs of torque (especially w/ a little work).
Old Skool ~
  • MTH76
  • MTH76's Avatar
02 May 2014 09:59
#631125
I sent you a PM.
  • MTH76
  • MTH76's Avatar
02 May 2014 10:13
#631127
I'm going to try this.
Attachment 20140413_173256.jpgKZphoto.jpg not found
  • slayer61
  • slayer61's Avatar
02 May 2014 12:25
#631134
As others have said....
You can't go wrong with the Motogpwerks unit
[IMG
