KZ750 Cylinder Head Flanged Bolts
- JRohrer
30 Apr 2014 13:03 - 30 Apr 2014 13:06
I had one of the center two cylinder head bolts brake on me.(NOT one of the Studs) To me they look like some type of stretch bolt that you would see on a car or truck head. Can someone tell me if they are a stretch bolt or if any bolt in that size would do in that area?
Thanks!
Thanks!
1983 KZ750-L3
Last edit: 30 Apr 2014 13:06 by JRohrer.
Re: KZ750 Cylinder Head Flanged Bolts
30 Apr 2014 18:47
Any bolt or stud would be fine. 99% of all motorcycles (that I'm aware of) don't have bolts like that and they get by just fine with straight shank bolts.
The following user(s) said Thank You: JRohrer
- JRohrer
30 Apr 2014 19:50
Thank you for the reassurance!! I feel the same way but just wanted to poll the guys that know more than me.
1983 KZ750-L3
- steell
30 Apr 2014 20:15
If the torque specs say something like XX Ft Lbs + XX degrees, that's a torque to yield bolt, and one time use.
If there are no degrees in the torque spec, then it's not a torque to yield.
- JRohrer
30 Apr 2014 20:19
Good point! "Steell" i didn't think about that. Looks like ill be getting the bike back together sooner than expected!
1983 KZ750-L3
01 May 2014 06:04
I would use high quality (not Home Depot) bolts. These folks have a very good selection in different grades. Ed
www.boltdepot.com/Metric_hex_bolts.aspx?nv=l
- JRohrer
01 May 2014 09:40
I have a great ACE Hardware that has a good selection of metric 10.9 so hopefully i can find them there. Sometimes i can get lucky and find stuff at Lowes in their metric bins Just don't bother asking for help finding them.
1983 KZ750-L3
- koolaid_kid
01 May 2014 10:02
Ace Hardware is an excellent place to source metric bolts, screws, nuts and washers. While their hardened stock is somewhat limited, I have been able to find some of the bolts I needed there.
Fastenal does not stock them, but can usually order them for you, if you are fortunate to have one near you.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Dr. Gamma
01 May 2014 11:23
Do it the right way, and just order two new bolts from Kawasaki.
They designed the motor, and for some reason they want that type of bolt there.
If my memory serves me correct, thats the two bolts that are located in the middle of the head at the front and back of the area where the cam chain comes up from the crank???
Their torque is not the same as the other cylinder head studs. Its only a 8mm size bolt.
1986 RG500G 2 stroke terror.
- JRohrer
04 May 2014 18:26
So i tried to do it right
Just got home from a short vacation and the new bolts came in the mail. checked the torque value in my manual that listed cylinder head bolt's at 22ftlbs . And this time the rear bolt broke. I have looked up the rated torque for a 10.9 8mm bolt and the max is 24 ft lbs. so the 22 that is listed in the manual seems right. I'm confused to say the least unless the bolts are of a lesser material. Anyone have a different value in a different book by chance or ran into this problem before? I have seen this value in both the service manual and Clymer. Well ill off to remove the head again and pray that i can extract this bolt with ease. I'm glad i ordered an extra bolt just in case this happened again.
Any ideas would be very helpful
Thanks for your time!
1983 KZ750-L3
- JRohrer
04 May 2014 19:28
After removing what was left of the old bolt it seems that the bolts are bottoming out and then snapping. Why would this be happening? The head gasket that i removed seems to be the same thickness as this one.
I'm to the point to where i might be installing washers under the center bolts just to keep them from bottoming out but still allowing plenty of thread bite. I would just have to make sure i don't drop a washer into the crank case.
1983 KZ750-L3
04 May 2014 20:10
Sorry if this is a dumb question, but are the bolts you're using 43mm? Ed
Attachment 00007_2014-05-04.jpg not found
