Is this a problem?
- Schmeck
Is this a problem?
28 Apr 2014 13:06
I finally got the sprocket cover off my 79 kz750 and found this on both sides. It is rough like sand paper . It doesn't appear to be causing any leaks but Is it safe to use the cover?
Attachment image_2014-04-28.jpg not found
Attachment image_2014-04-28-2.jpg not found
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
Re: Is this a problem?
28 Apr 2014 13:28
casting flash is not unusual to find on these old cast aluminum covers.
you will be just fine re-using it.
- Schmeck
28 Apr 2014 13:31
Okay kool. As for the seals for this cover, I have the part numbers but they do not come up when cross referenced at auto parts shops. Do you have to order them or is there an under the radar part number for the seals ?
- koolaid_kid
28 Apr 2014 14:11
Those seals will be metric. Does your database cover metric seals?
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Schmeck
28 Apr 2014 14:13
Database? If your talking about the parts store database then I don't know. I suppose I could just take down the measurements and go that way
- OnkelB
28 Apr 2014 14:18 - 28 Apr 2014 14:20
Z1E have them, several models use the same seals:
CLICK
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 28 Apr 2014 14:20 by OnkelB.
- Schmeck
28 Apr 2014 14:20
Thanks for the link . I know I can buy them online , was just seeing if maybe any local parts shops had them under another number you know .
- OnkelB
28 Apr 2014 14:32
Ah, okay - well, Z1E do list the dimensions, maybe taking those numbers to a parts shop that cater for metric cars would help.
- Schmeck
28 Apr 2014 14:36
Yeah I called around and it's an online order only thing unless I want it shipped from another dealer ( not free shipping ) . So I'll have to order them online and WAIT :evil:
