Just bought me a set of '83 GPZ1100 cams
- LarryC
Re: Just bought me a set of '83 GPZ1100 cams
08 Feb 2015 18:43
Forgot to add...if your cams look like the ones in the pic..... scotch brite is your friend....a few minutes and they'll look like new again. And if anyone else is looking for a set of those cams....I have 1 set.
Larry C.
- 4cyl h2
08 Feb 2015 20:37
larry ive got a project going and could use the buckets would be much appreciated
- daveo
09 Feb 2015 00:39
1982 KZ1100-A2/1170 sleeper 😀
- Moriwaki Kawasaki Monster
31 Mar 2016 23:31
Hi Larry
The Kawasaki GPZ 1100 Zx 83,84,85 model cam lobe specs are
CAM LOBE HEIGHT – 37.75 – 37.85mm - service limit 37.65mm ( base circle dia – 27mm )
(( After 30 years my friend has those cams measuring wear at 37.20mm ))
ZX1100-A1/A2/A3 GPZ, 1983/84/85 - 120 hp:
Intake (12044-1057)
Open: 40 BTDC
Close 80 ABDC
Duration: 300 - Lift: 9,6 mm (.375")
Exhaust (12044-1057)
Open: 80 BBDC
Close 40 ATDC
I want to use these cams in a Z1000MKII motor ( cam sprockets required )
The head to be used is a Z1000H (runs GPZ1100 size valves stock)
I am more interested in mid range power / torque, not top end power
It been suggested that some of the earlier model GPZ cams not having so much lift will not give the top end but will give better mid range power
Cam / model /specs preferred, what would you suggest ?
The engine is going in my 1980 Moriwaki Kawasaki Monster ( factory race bike )
Intake (12044-1057)
Open: 40 BTDC
Close 80 ABDC
Open: 80 BBDC
Close 40 ATDC
