Starter Motor Clutch kz750 1980
- Sharpe
24 Apr 2014 04:42
Hi,
I'm having what seems to be a fairly common problem with the starter motor clutch assembly, when starting the engine it would engage very briefly then sound like a pneumatic drill. I took the assembly out and one of the spring was jammed in the resess in the one way assembly, the assembly wasn't cracked how i'd imagined but there was a bit of ware there. Is it worth just replacing the one way assembly or is that one jammed spring enough to stop the thing working. I can't seem to find anywhere i can get a new assembly so if its just a case of a 3 quid spring id be a happy man. Any info would be much appreciated. Cheers
Re: Starter Motor Clutch kz750 1980
24 Apr 2014 05:26
Welcome aboard! Please identify your bike's specific model (adding it to the signature line is the best way). In 1980 Kawasaki made 3 different KZ750 models. They do not all use the same starter clutch parts, so it is important to know which model you have when trying to solve the problem. Ed
- Sharpe
Re: Starter Motor Clutch kz750E 1980
24 Apr 2014 16:09
Thanks Ed, sorry I forgot to mention that bit, its a four an E model. I'll get a picture of it on here within the next few days as it currently stands, its not looking to healthy at the moment though. Do you know where i could get hold of a starter motor clutch assembly from?
Many thanks
Many thanks
24 Apr 2014 16:56 - 24 Apr 2014 16:59
I bought Part #13193-1062 (CLUTCH-ASSY-ONEWAY) and it came with the springs, pins, and rollers along with the big piece marked #3 (parts marked #3, 4, 5, & 6 in red) . Kawasaki lists it as an "Active" part so any online or local dealer can order it for you. Ronayers.com lists it at $83.93. See
www.ronayers.com/Search.aspx?k=13193-1062
The part marked #18 in green also wears (see image down below for comparison of new and used ones). I would recommend replacing it while you have things pulled apart. Ronayers.com lists it at $43.94. See www.ronayers.com/Search.aspx?k=12046-1032 Ed
Attachment 00009_2014-04-24-2.jpg not found
Attachment StarterClutchComparison.jpg not found
Last edit: 24 Apr 2014 16:59 by 650ed.
- Sharpe
24 Apr 2014 18:39
Ed, thats very helpful, i'll be in touch and let you know how it all turns out. Thanks for your time and effort and a speedy response, I'll give Ronayers.com a go.
Cheers
Cheers
- ThatGPzGuy
24 Apr 2014 18:42
What 650ed posted is definitely the way to go. I did mine a few years ago and did not replace #3 and now I have to dive in again. No fun...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
24 Apr 2014 18:59
Here's some other info that may be helpful. Ed
forums.kz650.info/index.php?topic=5152.msg44173#msg44173
forums.kz650.info/index.php?action=dlatt...pic=586.0;attach=873
