Gpz 11oo clutch into kz 900
- The Banned
20 Apr 2014 07:38
Is the clutch/basket from the gpz1100 plug an play in the kz900 or a no go??
/Lars
/Lars
- les holt
Re: Gpz 11oo clutch into kz 900
20 Apr 2014 07:43
Most people go the other way as the KZ basket is stronger than the J/Gpz stuff so I guess it would, just can't say for sure.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
The following user(s) said Thank You: The Banned
- The Banned
20 Apr 2014 08:25
Thank you.... its a jungle sometimes- some prefere the mk11 due to the strong crank some want the kz900 due to the light crank
The GPZ clutch is lighter than the KZ etc etc etc
Do they have the same number of plates???
- les holt
20 Apr 2014 08:35
Yeah, same clutch kit. The J/Gpz trans is stronger and preferred over the KZ in high hp applications. It does go in KZ cases with a bearing swap.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- joe k
20 Apr 2014 09:23 - 20 Apr 2014 09:33The Banned wrote: Thank you.... its a jungle sometimes- some prefere the mk11 due to the strong crank some want the kz900 due to the light crank
Also need to change the input shaft if going to fit 83-84 gpz clutch as it needs slightly longer shaft , but not If you use 81-82 clutch.
Last edit: 20 Apr 2014 09:33 by joe k. Reason: spelling mistake
