Is my generator rotor in usable condition ?
  • Alka rider
  • Alka rider's Avatar Topic Author
19 Apr 2014 19:48
#629657
Kz1000
Rather not replace. Is it good enough to run ?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Is my generator rotor in usable condition ?
19 Apr 2014 21:58
#629670
The magnet toward the rear (second pic) looks like it has separated from the housing. Is that just an illusion, or has the bond broken at the middle of the magnet? When magnet pieces appear to be missing, they actually aren't. They are likely to be in the bottom of your oil pan. :(
1982 KZ1100-A2/1170 sleeper 😀
  • Alka rider
20 Apr 2014 13:12
#629742
It's still attached.
My question is , cAn I run it as is ?
I've looked into replacing it but they go around 3-400 new.
  • Nessism
  • Nessism's Avatar
20 Apr 2014 13:41
#629744
Some scratching and gouging shouldn't be a problem, but if the magnet is cracked or separating from the housing, even partially, you should replace it. As for the cost, have you checked ebay?
