KZ550 Cam end caps
- nickleo373
KZ550 Cam end caps
15 Apr 2014 16:51
Hey everyone.
My 81 Kz550 started leaking oil from the cam end caps and it's splattering oil all over the outside of my air box while I'm riding. Does this mean the cam end caps are bad or do they just need to be resealed with gasket sealer? My valve cover gasket doesn't appear to be leaking but is it a normal thing to replace when the cam end caps are leaking?
1981 KZ550C LTD
"If you ain't first, you're last"
- NHenneous
Re: KZ550 Cam end caps
15 Apr 2014 16:59
I would replace both while you have the valve cover off
NHenneous
- loudhvx
15 Apr 2014 22:31
The 550 uses bolts through the cam end caps so they usually don't have a problem with leaking like some of the bigger KZ's. A clean up and a little silicone, (very little) around the cam ends should seal it up as long as nothing is cracked.
Can't remember if you've already had the cover off, but if not, you should read the valve cover/valve-train warning in my signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- nickleo373
15 Apr 2014 22:49
I'm thinking I might as well just replace the caps since they have to come out anyway. Do you recommend just using silicone on the new caps or should gasket sealer be used? Just read the valve train warning. I'll make sure the tensioner is removed. Thanks
1981 KZ550C LTD
- loudhvx
16 Apr 2014 09:39
I use a very thin smear of red RTV. If the rubber is hard and brittle, I would get new ones, but the old ones are usually fine.
I clean the gasket surfaces to a smooth semi-polish, then use a smear of antiseize on the gasket. It comes off like new next time, and can be reused (as long as it goes back on in the same orientation).
You don't have to remove the tensioner, just the 17mm cap, spring and crosswedge.
1981 KZ550 D1 gpz.
Other links.
Other links.
The following user(s) said Thank You: nickleo373
- bountyhunter
17 Apr 2014 16:29
For many years, I reused the hardened end plugs using sealer. Any good silicone sealer will work. I would always seal the curved surface and set the plugs in and align the tops with a straight edge and let the sealer dry overnight. Then when installing the valve cover gasket, I put a line of sealer across the tops of the plugs plus a couple of inches to make sure and get a seal.
