EBay Piston Kit?
  • NakedFun
  • NakedFun's Avatar Topic Author
EBay Piston Kit?
13 Apr 2014 19:58
#628935
No eBay APP ID and/or Cert ID defined in Kunena configurationI keep looking at this:
Anyone heard of these or used them? They are 69mm and give a compression bump of .5 points. Thoughts on this?
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • martin_csr
  • martin_csr's Avatar
Re: EBay Piston Kit?
13 Apr 2014 20:54 - 13 Apr 2014 21:05
#628940
[strike]Just a comment about the description... maybe the problem's with my computer... Is the text messed up?[/strike] Edit: I guess the page loaded wrong.... it's fine now.
Last edit: 13 Apr 2014 21:05 by martin_csr.
13 Apr 2014 21:00
#628943
Good Fortune! :)
  • NakedFun
14 Apr 2014 10:26
#628993
So I assume nobody has used these before? Hmm....may just contact the seller for more information.....
Cory
1976 Kawasaki KZ900
  • NakedFun
14 Apr 2014 17:26
#629031
Reply from the seller....
Hi Cory
We buy these pistons from a Japanese factory rep. I don't know the name of the manufacturer and he won't tell me the source. I suppose he doesn't want me to bypass him. We buy lots of different motorcycle pistons from him and they come from various factories. These are copies of the original Kawasaki castings and the quality is very good. The increase in compression comes from the bore increase only. The dome is the same height as stock. The coating is done by us in Canada. The pistons carry a factory warranty which we honor here. The coating has a coverage and adhesion guarantee from us but does not have any performance oriented warranty. The coatings are manufactured in the USA by Techline.
Thanks for your interest.
Andy
XScycle Canada
1976 Kawasaki KZ900
  • martin_csr
15 Apr 2014 08:12
#629100
It seems worth noting that he didn't say where the various factories are located (china?).
And the coatings don't have any performance oriented warranty, which seems to be in direct contrast to the amount of hyperbole (BS) in the item description.
  • NakedFun
15 Apr 2014 08:46 - 15 Apr 2014 08:47
#629103
The pistons are supposedly Japenese manufactured. As far as garunteeing performance increase due to the coatings, that is no surprise there. I can 't name one manufacturer that will garuntee a HP increase number or performance metric for their product. There are too many variables that contribute to overall engine performance and one as slight as coatings would not yield a hard, tangible number that could be repeated. I mean how many manufacturers stand behind their fuel consumption numbers on the sticker of your car? If your car doesn't make those numbers, they simply tell you it's an average and that your driving and route are probable causing you not to hit your targets, so that is pretty standard to me...,
Cory
1976 Kawasaki KZ900
Last edit: 15 Apr 2014 08:47 by NakedFun.
  • mopguy
  • mopguy's Avatar
15 Apr 2014 09:12
#629110
Google xscycle for reviews.
