Back firing from number 4
  • hotdogg
  • hotdogg's Avatar Topic Author
  • 1982 kz750 spectre
13 Apr 2014 07:27
#628857
Can anyone give me some reasons for backfiring through my number 4 carb...thanks...Its a 1982 kz750 spectre
1982 kz750 spectre
  • hotdogg
Re: Back firing from number 4
13 Apr 2014 07:37
#628859
it has a 4 to 1 exhaust also
1982 kz750 spectre
13 Apr 2014 07:50
#628862
hotdogg wrote: Can anyone give me some reasons for backfiring through my number 4 carb...thanks...Its a 1982 kz750 spectre
Possibly insufficient clearance on the intake valve.
Good Fortune! :)
The following user(s) said Thank You: hotdogg
  • hotdogg
13 Apr 2014 08:10
#628866
thanks bud
1982 kz750 spectre
13 Apr 2014 08:25
#628869
Is it backfiring throughout the rpm range on only at idle? If it is at idle or very low rpm it may be the carb holders. You can easily check them to see if they are leaking; if they are the bike will very likely backfire at low or idle rpm (mine did). Here's some info on the carb holder test. Ed
www.kzrider.com/forum/3-carburetor/59338...sync-78-kz750#628442
  • hotdogg
13 Apr 2014 09:16
#628872
it does it when i rev it and on the way back down to idle..but not at idle..
1982 kz750 spectre
13 Apr 2014 10:11 - 13 Apr 2014 10:14
#628878
If not already done, would assure functioning of the timing advancer by viewing it with strobe-type timing light, and watching for the arms to quickly move back and forth as rpm is varied by blipping the throttle.
It's possible that the advancer is hanging slightly and not immediately returning to fully closed idle position when the throttle is closed.
Perhaps the pivot points need lubing (sometimes possible by accessing through the timing window).
The advancer should NOT look like this:
Good Fortune! :)
Last edit: 13 Apr 2014 10:14 by Patton.
  • hotdogg
13 Apr 2014 11:34
#628886
I will check that tomorrow. Thanks a lot you have been really helpfull
1982 kz750 spectre
  • hotdogg
15 Sep 2014 19:57
#647711
It was the advacer was stuck but I replaced the card boots anyway.. Thanks a lot I would have never found that timing problem..
1982 kz750 spectre
