Running on two cylinders
- freakinbike
Cylinder #1 and #2 do not fire. All across the head I have 140-150psi, and strong spark. It seems that they're not getting fuel, as I couldn't smell any coming out of the spark plug hole or on the spark plug itself. My carbs are freshly rebuilt, and even so, I went through and cleaned them again. Nothing changed. I tried running the bike without the airbox and spraying carb cleaner into the open carbs and got nothing.
The bike backfires through the carbs occasionally, could this be a timing issue? I checked the timing advancer and it seemed stuck, so I'm currently getting it back up to spec. Should I check the cam timing as well? I just finished a head rebuild so I'm confident that it's all correct, but you never know. Or could this be electrical?
Thank you for the help!
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- Thank you received: 2829
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- freakinbike
Would someone happen to know the stock float height perchance?
1973 VW Bus
- loudhvx
The coil firing #1 and #4 will have a black wire.
The coil firing #2 and #3 will have a green wire.
1981 KZ550 D1 gpz.
Other links.
- nickleo373
www.kawasakimotorcycle.org/forum/mechani...-float-question.html
1981 KZ550C LTD
- freakinbike
loudhvx wrote: As Ed mentioned, one coil fires the # 2 and #3 plugs, while the other coil fires the #1 and #4.
Right, and #3 and #4 fire beautifully, which leads me to believe that the arrangement isn't an issue. Even so, I'll see what I can do.
I did find the stock float height: 18.6mm and have adjusted each carb as such. None were that far off. So I did a fuel height check immediately afterward and all four carbs seem to have the correct fuel heights.
1973 VW Bus
- Thank you received: 2098
freakinbike wrote: 1982 GPZ750
The bike backfires through the carbs occasionally....
Which cylinder(s) is/are backfiring through the carbs occasionally?
Has starting fluid spray been tried instead of carb cleaner?
What ignition?
What plug wires?
What spark plugs?
- freakinbike
What ignition?
What plug wires?
What spark plugs?
Cylinder #1 is the one backfiring through the carb, I believe. I have not tried using starting fluid.
I'm using stock ignition with NGK BSE8 plugs in all four cylinders, Dyna 3.0ohm coils, and 7mm dynatek copper wire.
1973 VW Bus
- gd4now
- Denco where did you go?
- Thank you received: 438
If on the other hand all 4 are sparking but 1 and 2 are not running then check the carbs for clogs, proper fuel levels, air/vacuum leaks.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- freakinbike
gd4now wrote: First do all four spark, or do you get no spark on 1 and 2? If both of them are not sparking then I would suggest you check the spark plug caps and make sure they have not gone south. If they are fine try snipping a small amount off of the cable and then re install the caps.
Ran through this. I have spark across all four and went through, again, cleaning my carbs. I checked my fuel levels and set them to the stock height and got nothing. Checked vacuum lines and everything is in order. If I deleted my silencer, would that have any positive effects on this situation?
1973 VW Bus
