Oil Pressure Questions
- bLodi
Re: Oil Pressure Questions
09 Apr 2014 17:20 - 09 Apr 2014 17:23
Well I got a little over excited about it and tore it apart. I needed to pull the exhaust to get the oil filter out for a change anyways. Here is what I found...a bit debris in the pan...not near what I found a few years ago when I pulled it. The screen does have some debris in it, but nothing that should limit flow significantly (see pic). Then I submerged the pickup portion of the pump into the oil I had drained and spun it by hand and it does seem to be pumping oil. Not sure if this is sufficient or not, so I took a video....see below. I get my "new" one probably friday or saturday, so I can do the same with it and compare.
If it is my light that is just acting up...it only really would be the oil pressure switch right? I just replaced the switch with a NOS one. Question, should there be anything between the switch and the filter tube to help switch it on? I can look right up where the filter screws in and see the bottom of the switch.
Video link.....
flic.kr/p/mWUBk6
Attachment IMG_20140409_184447.jpg not found
Video link.....
flic.kr/p/mWUBk6
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
\\\\\\\'74 Z1
Last edit: 09 Apr 2014 17:23 by bLodi.
- Powerstroke_fan
09 Apr 2014 19:17
You should be able to see the bottom of the switch.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- ZERO
10 Apr 2014 04:54
How are your cam bearings? In the past, I've had two Zs that the oil light would indicate on and both of them had worn cam bearings that allowed the pressure to bleed down.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
- bLodi
10 Apr 2014 05:35 - 10 Apr 2014 06:06ZERO wrote: How are your cam bearings? In the past, I've had two Zs that the oil light would indicate on and both of them had worn cam bearings that allowed the pressure to bleed down.
Good question. I have no idea. Just had the cams out to double check the cam timing and don't really know how to inspect/measure them.
Bike has 34K on it and as far as I know the bearings have never been replaced.
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
Last edit: 10 Apr 2014 06:06 by bLodi.
- bLodi
10 Apr 2014 06:20 - 10 Apr 2014 06:54
Where are 31-34 on this diagram located? Is this the pressure relief valve? I don't see them on my bike......
Also, I never had replaced the oring that goes in the oilpan around the oil filter, gonna go ahead and order one today, maybe not a bad idea to replace the oring that goes between the oil pump and crank case too.
Attachment Oilpan.jpg not found
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
Last edit: 10 Apr 2014 06:54 by bLodi.
- bLodi
10 Apr 2014 13:16
Found this in the service manual too....might be worth a shot on my old switch if things are still not right when I reassemble everything....
Attachment Switch.jpg not found
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
10 Apr 2014 15:30bLodi wrote: ...Just had the cams out to double check the cam timing....
Uncertain why it would have been necessary to remove the cams incident to checking the cam timing (as opposed to adjusting valve clearances where the bucket is removed in order to access the shim).
In any event, the cam caps should be replaced in exactly the same positions from which they were removed. The FSM may include a photo showing the position of each numbered cap.
The following user(s) said Thank You: wargoth
- LarryC
10 Apr 2014 17:52 - 10 Apr 2014 17:57
Two things will cause that.
1 - Somebody left out the o ring that goes between the pan and the filter housing boss on the bottom case.
2- The switch is bad.
Bad pump.....perhaps but I seriously doubt it.
Larry C.
Last edit: 10 Apr 2014 17:57 by LarryC.
- bLodi
10 Apr 2014 19:34
Patton-I should have specified. I took the cams out to reset the timing after I realized both cams appeared to be one tooth retarded. So, I reset them per the manual directions and now they are dead on. I did replace all the caps/bearings as they were previously.
Larry- I did not replace the o ring you are referring to between the pan and lower case the last time I dropped the pan a few years ago. I did notice it seems rather "flattened" this time pulling it out. Possible it just wasn't sealing this whole time, pretty sure I've "overfilled" it since then to keep the light off. I've ordered a new one and every other o-ring in the pan/pump/filter area. You might be right on with that suggestion. I've also ordered an oil pressure gauge so I can see if the oil pressure switch/light are BSing me.
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
- bLodi
15 Apr 2014 16:30
Well, I think Larry was right on with the o ring suggestion. I got my new orings and seals today and finally put it back together along with adding an oil pressure gauge. Filled to the correct amount of oil....no light! And good pressure according to what I've read here on the gauge. That o ring around the filter between the pan and block was really flattened and probably wasn't sealing.
Happy that it's all back together and running great again! Thanks guys!
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
