Valve Cover Vent Size?
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
08 Apr 2014 17:35
#628360
I want to put a NPT to AN fitting in valve cover and vent it to kick block off plate.
My question to the forum, should it be 1/4, 3/8 or 1/2 hose?
I was considering 6-AN fittings with 3/8 stainless braded line.
Anyone gone down this path?
Thanks
  • zed1015
  • zed1015's Avatar
Re: Valve Cover Vent Size?
09 Apr 2014 02:05
#628382
The bigger the breather the better really but obviously a big block motor would benefit from breathers larger than say those needed for a std one.
Breathers need to vent to atmosphere though, not to another part of the engine.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
09 Apr 2014 07:55
#628402
Of course, it's a completely different animal, but I have a 1 1/4" breather hose on my flattracker. It needs to flow over 1300cc of air on every revolution. :woohoo:
[IMG
  • StreetfighterKz
  • StreetfighterKz's Avatar
09 Apr 2014 10:12
#628422
I agree with Zed on this. Going from the valve cover to the kicker area isn't venting the crankcase as it's all the same cavity. I'm thinking of running at least -8 hose from the stock breather and maybe a -10 or -12 from the kicker plate on my 900 when I get to that point.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
09 Apr 2014 14:37
#628446
If you have a emission style valve cover like I do, you can remove the reed valves and drill holes in the valve cover inside the emission plates and run a hose from them to vent to atmosphere.
1977 KZ 1000 work in progress
