Preference on KZ900 parts
  • b0ssdawg
  • b0ssdawg's Avatar Topic Author
07 Apr 2014 20:16
#628274
So here is what I'm looking to change out, just looking for preferences and fair priced parts for the following
-Coils and wires
-Spark plugs
-Chain and sprocket
-Clutch pads
-Tires
Thanks
Rusty old 1976 kz900
  • MDawnz1
  • MDawnz1's Avatar
Re: Preference on KZ900 parts
07 Apr 2014 20:59
#628276
Nothing on your list that you want to go cheap on,
Coils , I use Dyna
Plug wires , Taylor
Plugs, ND
Chain,Tsubaki ONLY
Sprocket, The best I can afford
Clutch PADS ? If you mean fiber plates Vesra work for me
Tires , Metzler
1974 Z1a, still 903
  • LarryC
  • LarryC's Avatar
08 Apr 2014 04:12
#628303
Put OEM Kawasaki clutch plates in it. There is nothing better.
Larry C.
  • b0ssdawg
08 Apr 2014 18:24 - 09 Apr 2014 09:37
#628368
No eBay APP ID and/or Cert ID defined in Kunena configurationthanks for the advice so these wires and coils look good then?
there is too many chains to choose from Lube-Free Drive Chains, Corrosion Resistant Drive Chains, etc
Last edit: 09 Apr 2014 09:37 by b0ssdawg.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
09 Apr 2014 03:41
#628384
A lot of riders buy their parts from Z1Enterprises. I would go with the smaller chain size.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
09 Apr 2014 14:48 - 09 Apr 2014 14:51
#628449
I personally run dyna coils and 8mm solid core wires. ngk b8es plugs. stock kaw clutch plates. I run a D.I.D. race chain. and a custom rear sprocket from sidewinder. The sprocket I bought from sidewinder is guaranteed to never fail or wear out, not sure which brand front sprocket. And for tires im running a bridgestone battlax on the rear, cant remember on the front. But then i should say i didn't cheap out on any of those parts. im sure there is cheaper stuff out there.
1977 KZ 1000 work in progress
Last edit: 09 Apr 2014 14:51 by Powerstroke_fan.
