ZX750 cams in 1982 GPZ 750
- freakinbike
07 Apr 2014 12:08
I've heard of this swap in the gpzfaq and am just wondering what modifications (if any) are required with it. Will the cams need to be degreed? Does it matter if the "new" cams are from a turbo or non-turbo?
I'm assuming the valves will need to be adjusted as well, then the carbs.
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
1973 VW Bus
- Dr. Gamma
Re: ZX750 cams in 1982 GPZ 750
07 Apr 2014 12:27 - 07 Apr 2014 12:28
The Turbo 750 (ZX750E1,E2) cams are nothing more than stock KZ650 cams.
Make sure you get the cams from the ZX750A1,A2,A3 (1983`1985) GPz750's
1986 RG500G 2 stroke terror.
Last edit: 07 Apr 2014 12:28 by Dr. Gamma. Reason: badd grammer
- turboguzzi
08 Apr 2014 14:21
the base circle in the ZX exhaust cams is different than KZ/early Gpz. they can be used but with some mods / thicker shims ( if i remember right), so not exactly bolt on
the catalog in megacycle's site explains that
