1983 kz440 won't Rev up
- Shawn420
05 Apr 2014 09:21
So I have had this bike for a few years now and think it's about time to get it running. It will start up and idle nicely. When you try to Rev it up it will spit and sputter it's way up to around 6-7000 rpm and it sounds horrible. I had the carbs off and cleaned them really meticulously. That improved it a bit but still running really rough and slow to Rev. What should I be checking? Timing? Valves? How do I tell if the timing advancer is functioning properly? Anything you guy's could tell this newbie would be much appreciated. I do all the work on my snowmobile but not very familiar with bikes. Thanks in advance for your help.
Shawn
Shawn
- loudhvx
Re: 1983 kz440 won't Rev up
05 Apr 2014 10:07
It could be timing advancer, main or secondary jetting, or enricher circuit, or torn diaphragms on the carb slides, and probably a few other things, even fuel flow.
If it idles fine, it's probably not the valves.
If you don't have a manual, I would get one, as that will help with all of the above.
You need a timing light to verify the proper advance.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Shawn420
06 Apr 2014 08:16
The airbox is there but there is not a filter.
- Nebr_Rex
06 Apr 2014 10:41Shawn420 wrote: The airbox is there but there is not a filter.
The filter is just a piece of foam.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
06 Apr 2014 11:31 - 06 Apr 2014 16:27
I whould install the air filter. There should be a filter element case to hold the filter element & an airbox cap. Make sure the airbox cap is secured correctly. The KZ440 is known to need a properly installed stock airbox to run right.
Last edit: 06 Apr 2014 16:27 by martin_csr.
