KZ 250 Transmission related noise
- nicholsm4
05 Apr 2014 07:31
I recently picked up a KZ 250 with an '81 model engine in it. Engine running fine no noise . Once I engage clutch and start driving there is a high pitched whine coming from the right side of the engine. It stops when I disengage the clutch so it appears to be transmission speed related. Just changed oil, adjusted chain etc. Any ideas?
Re: KZ 250 Transmission related noise
05 Apr 2014 08:09 - 05 Apr 2014 08:09
Was the noise present before you adjusted your chain? Did you leave the specified amount of slack in the chain? Chain must have slack. Ed
Last edit: 05 Apr 2014 08:09 by 650ed.
- nicholsm4
05 Apr 2014 09:45
Thanks for the reply. I put new chain and sprockets. Checked the slack and is about 1.5" to 2" at the loosest point. I will put on center stand and check again. Thanks
