help with a 1980 kz550 ltd in storage for 20 years
- savage388
04 Apr 2014 21:04 #627911
by savage388
help with a 1980 kz550 ltd in storage for 20 years was created by savage388
Hello this is my first post and it's really for my dad, he's had his 550 ltd since 1979 and when I was born in 93 he stopped riding and put the bike into storage. He's tried a few times to get it running but just last year I made him dig into it and clean tarnish out of the carbs. They're probably way off but it's not getting spark for some reason either, one coil tested bad on it but we have no clue where to get one as these don't seem to be very common old bikes. Aside from that, what else do we need to do to get this in running shape, it's in really beautiful condition for a 34 year old bike.
- kaw-a-holic
- Thank you received: 249
05 Apr 2014 08:31 - 05 Apr 2014 08:33 #627949
by kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Replied by kaw-a-holic on topic help with a 1980 kz550 ltd in storage for 20 years
www.z1enterprizes.com
carries parts for these old kaws. You may want to consider switching to a Dyna S ignition. It replaces the points.
Jon
1977 KZ1000a1
Mesa, AZ
Last edit: 05 Apr 2014 08:33 by kaw-a-holic.
- loudhvx
- Thank you received: 1616
05 Apr 2014 10:13 #627960
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic help with a 1980 kz550 ltd in storage for 20 years
I think your bike is a 1980 Kz550C1. I thought that bike comes with electronic ignition, which, if working, is better than a Dyna S, especially since I think you should also have a single-phase charging system. Later years had 3-phase (and it's not too hard to convert, if necessary).
In my signature are several manuals for that bike, You should download all of them.
Also, read the valve train warning before removing the valve cover.
Coils are not too hard to get. You can use 3-ohm, green, Dyna coils or 3-ohm Accel supercoils, but the 2.2-ohm, gray, Dyna coils are probably best suited for the factory electronic ignition. You can probably use used coils from any KZ550 or ZX550.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: savage388
- savage388
06 Apr 2014 17:09 #628120
by savage388
Replied by savage388 on topic help with a 1980 kz550 ltd in storage for 20 years
Your signature is very helpful, pretty much everything I need to know is in there. I'm very mechanically inclined and used to working on cars but motorcycles are a bit different.
